Hello everyone. Getting the bike ready for the season, a 2001 Honda Rancher 350 ES 2x4. Pulled it out of the shed, removed all the plastics and began making minor adjustments and fixes to things. Before this began there was no issue with high idle, now when I start it up it idles high and the choke is pretty much unresponsive. When engaging or disengaging the choke it will affect the idle but only momentarily. Listed below is a list of everything done so far. Any recommendations on how to get the idle back to normal are always greatly appreciated.
-all plastics remove, fuel tank removed, and air cleaner housing removed
-adjust the reverse cable that runs from the left-hand control to the bottom of the motor
-adjusted valves from .20 to .06
-changed gear oil in the rear end
-adjusted rear brakes
-removed oil temp switch wire and grounded to the engine block to allow constant use of the fan
