Don't you love it when a bunch of cheap bikes pop up all around you at the same time, usually when you're broke as heck and so busy you can't take the time to get them?
Picked up that 07 500 last Wed, which is now stuffed into long term storage.
Saturday this 300 popped up in a little-used FB trading page.
4wd, complete, ROUGH, $200
Guy was an hour from me, so I asked him how early I could get it Sunday morning, got up at 5:30 to go get it, and was home in time for church.
Then Sunday another 300 popped up for $250, new top end, needed bottom end work so not running, but complete, and had good plastics. This one was > 2 hours away, I'm broke, and no way to get it.
So on the one I did get, the sticker up front says "198?" The sticker is messed up so can't read the last number. The good....It's all there, and it was cheap.
The bad.....
Plastics are done. Front fender is literally held together with wire and plastic.
Front left wheel is \ and the CV axle and likely the knuckle are destroyed
Plan is to strip it down, go through the motor, swap in the TRX250 rear end I have had sitting in the back for a year or so, probably do a disc brake conversion, and put some new or at least decent plastics on it.
Will probably be awhile before I start on it. Still trying to find time to finish my buddy's Rincon, and I am almost through with my wife's uncle's 350 Rancher.
The bad.....
