1 - 1 of 1 Posts
Editorial Content
We did some digging and found some deals on ATV and UTV accessories and some useful items that off-roaders can take advantage of.
More items will be added throughout the day on Oct. 13 and 14. Check out ATV.com for those latest deals.
Baja Designs 20" Light Bar - 16% Off
150963
Help light up the way when your next ATV or UTV eperience starts before the sun rises with this Baja Designs 20″ light bar. Features include aluminum frame construction, 8000 lumens of output, low 6.66-amp draw, nearly 50,000 hours of LED life, upgraded reflectors, amber backlit feature, and new scalloped housing design.
Buy it now
Portable Jump Starter - 13% Off
150964
If you accidentally run the battery down in your ATV, UTV or tow vehicle when you are far off the beaten path, a portable jump starter can be a life saver. The Tack Life T8 is designed to jump start up to 30 vehicles on one charge and can handle engine sizes up 7.0-liter gas engines or 5.5-liter diesel engines. When not in use, you can turn the Tack Life T8 off to hold its charge for up to 12 months. It also features bright LEDs that function as a flashlight and it comes with smart jumper cables, wall charger, car charger, USB cable, cigarette lighter socket adapter, EVA carrying case, and a two-year warranty.
Buy it now
ATV Seat Cover/Pad – 10% Off
150965
For under $20, it’s hard to beat the MadDog Gearcomfort seat pad. This is a soft-molded foam pad that is designed to provide you a little extra cushion for those long ride days. But beyond the comfort boost, it also helps cover up any rips or tears on your existing seat and helps stop them from getting bigger.
Buy it now
Ratchet Straps - 22% Off
150966
A good set of ratchet straps can be invaluable to an ATV or UTV owner, Whether you use them for strapping your vehicle down to a trailer or for holding down cargo in your truck, you will be glad to have them on hand. This ratchet strap kit from Sunferno comes with four ratcheting straps, four loop straps, carry bag, and even a ratcheting guide book. Rated for 2500 pounds of break strength, these straps are available for a killer deal right now.
Buy it now
Goggles – 28% Off
150967
Fox Racing has an impressive lineup of goggles and we don't see big sales very often, which is why you should consider jumping on this 2020 Fox Racing Vue S goggle. It is currently 28% off, saving you almost $40 off retail. The Vue S is designed specifically for riding in sand and it features closed cell vent foam to keep the sand from getting in. The Vue S also comes with anti-fog treatment on the lens and tear-offs come standard.
Buy it now
Spot Gen3 Satellite GPS Messenger – $24 Off
150968
Off-road adventures can take you to some far away places that cell phone towers can't reach. When you are far off the beater path, the Spot Gen3 satellite GPS messenger can come in really handy - and right now it's on a rare sale for 33% off. This device lets friends and family know you are OK and, if things get out of hand, will send emergency responders your GPS location. This could quite literally be a life saver!
Buy it now
We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
1 - 1 of 1 Posts
