HELLO, NEW HERE. I HAVE A 1994 HONDA FOUR TRX 300. I NEED TO KEEP AJUSTING THE ROCKERS. VERY LOUD. WHY THE NEED FOR REAJUSTMENTS. SETTING THEM AT 6 THOUSANDS. THANKS
not very long, thinking maybe the cam is gone. your thoughts would be helpful. thanks
I think your right. You should take off your rockerarm housing and check your cam out. I've had something similar happen with my 300. What happened was the oil filter (I never change or check them) got clogged up after the motor ate a couple of bolts and was not allowing oil through to the head which burnt up the cam, rockerarm housing, and the head. So you might wanna check that cam before it messes something else up.
