i was wanting to adjust my rockers.how exactly do i do this and do i have to drain the oil.i have feeler gauges already.
you mean adjust your valves ?..put the piston on TDC on the compresson stroke...loosen the 10 mm nut on top of both valves..put the fealer gauge under the rocker where it sets on top on the valve spring..screw the center small bolt down onto the fealer gauge..then tighten the 10 mm nut..hope this helps.
Make sure the engine is cold and don't tighten the bolt down tight on the feeler gauge. Just tighten it down until it tips the gauge and you should be able to easily pull the gauge out. Make sure you tighten the lock nut up good and tight or they might loosen back up.
And also you don't have to drain the oil.
Yeah, I forgot that he had asked that. LOL.
alright thanks.its been a about 10hrs at least since i had cam put in and seems like there tapping louder so i wanted to check them.thanks for the tips.
