Ill try to post some pics if I can remember.
Thanks Goober! I did see that kit, and as a matter of fact, its sitting on my desk. But, I did not like the switch dangling around. I had another one that has a lighted switch, but it does not mount to the handlebar, and it doesn't need to be lighted considering its hooked up to the ignition. So, I just ordered some relays, fuses, and this switch:
https://www.amazon.com/iWonow-Motor...24867&sr=8-3&keywords=motorcycle+light+switch
It is admittedly, not built as well as I would like, but the price is right, and its going to work. I also just did not need a ton of harness that I had to ultimately cut and shorten and solder anyway. Also, its 16ga wire. I wanted to go a hair bigger....why....because in wiring, bigger is better. Maybe my chinese light shorts out and pulls a ton of amps before that fuse burns, maybe it chaffs and shorts...I don't know. Mostly though, I wanted to have a solid supple wire to my relay in case I wanted something else later. I can just add a relay, tap off the hot, and we're on our way. I mounted the relay in the front near the switches and lights and found a handy 6mm bolt that already had a ground on it. So, the relay ground went to it along with the light ground, and the relay mounted on the bolt too.
Here is the album of the my quad. It should be obvious which is the light setup. LOL.
https://goo.gl/photos/S2ymgxRSnKgo4x8j6
Hopefully this works.
I wish I would have used PVC sheathing instead of split loom. It would have looked cleaner and more factory but, this stuff will work OK and protect the wires from chaffing which is what I wanted. I also don't like crimp connectors, but sometimes you just have to use them. I think you can click on the pics and the description is in there. See what you think.
I would have loved to replace the factory light with LED, but due to the way its mounted, it would have required some sizable modification to make that work. So...in lieu of that, I went with a 12" light bar that has a spot beam in the middle and floods on the side. We will see how they work. Hopefully they put out a nice beam. If not, I have a desk full of other LED that I can play with, but Ill probably leave this. At least this way, you can still have a headlight that lights up where you TURN instead of where you are POINTING. I even had a convenient hole in the fender to run the wire! LOL.
