I am about finished getting my 2001 Honda Fourtrax(Rancher)350FM back to running condition. Got some good used steering components installed and now the steering is tight. Tonight I finally got the almost new Mud Bugs installed. That was a trial, let me tell you. Had to cut the old front tires off the rims and snip the bead wires one by one until it finally let go. I then had a little idea for the rear tires. I left about 3 lbs of air in the tires and used my Princess Auto(Harbor Frt) tire bead breaker. That worked a charm as the pressure kept the wall from collapseing and kept the breaker spade close to the rim. Then---poof the beads dropped off the rim. Too easy when the right trick is used. BUT---getting the new tires to bead set was another story. The front ones went fairly well, but the back ones just would not seat, no matter what I tried--and I tried all of the tricks----but ONE. So, in desperation, I broke out the old starter fluid can(ether), took the tire and a tire iron out to the front wall, and armed with a packet of penny matches, I plied the supreme red neck trick. A two second burst of ether into the crack betweer tire and rim--a quick flick of the match and an accurate toss and run. Pffffttt and whoosh--followed very quickly by a pop pop as both beads seated. I had the tire iron stuck just in the edge of the rim to allow the match flame to set off the ether. That sucker flew about 10 feet up in the air and landed straight down and stuck into the grass of the lawn.
Well, this was just too good to not have a spectactor for the second tire, so I called my better half out to have a look at this spectacular bit of foolery. Of course she stayed back a good 25 feet from ground zero. I added about 2.5 seconds of ether--just to see how high the iron would go. Well, the beads seated but the iron only went a dissapointing 5 feet.
I have seen videos of this procedure, but have never tried it. Now I am here to tell you that it works. But ya gotta be very careful about the quantity of ether. Too much and ya might blow yourself up.:icon_ devil:
