Hey everyone, I have a 99 2x4 fourtrax 300. It says its a 300x but can't find that as an option on parts site. It is the same as a fw just 2x4.
Also looking to make it 4x4 and have found a good parts bike with a blown motor but its a 95 and also need a new rear end... would my motor and rear end work?
Partzilla lists it as a "TRX300 A". Yes, everything from your 99 should swap over to the 95 4x4 frame. 93-00 were essentially the same.
Thank you blackout. Any chance you know of a forum that gives measurements and angles on lifts? I'm not gonna spend 1500+ on one when I could build it myself with the right guidance
Highlifter forum and Facebook. Most run the 2" bolt in highlifter lift. To go beyond that, it seems most cut the frame at the top and add some pipe, stretch the swing arm, and custom drop a-arms. Lots of pics on the two places I mentioned.
