Original problem, no charge. Running fine. Little hard to start, but once started ran fine. After checking, stator showed bad. Replaced stator and pulse generator while having it apart. Also took bowl off carb while it was out, done a mediocre cleaning. New air filter. Everything back together, checked my readings on stator and pulse, right with manual. Here's problem, when cranking now it acts like it's out of time. Like it fires only a quarter of every stroke. And it's somewhat loud when it does. Louder, little more violent then usual. I've double checked everything, it doesn't appear changing stator has any to do with timing. Does this sound like I've got a problem with carb
