I've got a 99' 300 FW 4x4 that I've worked on off and on for a while now. Recently, I'm having a new issue with it, when I turn the key on, all of the lights will come on, then when I press the start button, there is a click then the lights turn-off and it won't start. I can turn the key off and on after this and the lights will stay off, but if I disconnect the fuses, let it sit, then reconnect the fuses the lights will come back on and the same thing will happen.
In the past year, I've changed the Front Lights, battery, regulator, selanoid and starter. I wonder if it is the CDI, but this doesn't seem like an issue it would cause. I've traced the wire harness for shorts and checks all grounds, nothing seems to be amiss there.
Thoughts???
Thoughts???
