Hi folks
I just replaced the 1 way bearing (starter bearing) in my 1998 Honda Foreman 450s 4x4. I put it back together, turn the key, and no neutral light. I shift up 3 gears and i get the reverse light. While holding the start button, between the reverse light and the next gear up the starter will turn for a second. Im wondering if i missed something, didn't line something up right or reset something? Any and all help is appreciated. Thanks and god bless
You didnt install the gear position indicator correctly. It is inside the rear alternator cover. There is a certain way that little piece has to be lined up.
Ok, I removed the rear cover. Do you know how it needs to be lined up? I was rotating it with the key on and had a reverse light. Maybe the rear cover needs to be installed and all bolted up to get a green light? Thanks guys i really appreciate the help
