1 - 13 of 13 Posts
I'm not sure if it can be bypassed I would have to look at a schematic. I'll get back to you if someone dosen't help you put first.
Here's the wiring diagram.
Looks like you would have to jumper the reverse switch, neutral switch, and the clutch switch for starters.
The clutch switch should be up on the handle bars on the clutch perch. If I remember correct;y it makes a clicking sound when you pull in the clutch. Join those wires together and you will not have to pull the clutch to start it.
allready got neutral & reverse switch jumped to ground..
Will hook clutch wire 2gether also..
thanks guys
1 - 13 of 13 Posts
