When i shift it into gear from neutral it jumps alittle like clutch isnt pulled in then its ok.
Also noticed that it does same thang when shifting into reverse..
Clutch pulls fine definitely ant slipping..
Last clue i got..is that when its n gear and not running.i pull clutch to push it out of way it wont roll. unless shifted to neutral..
i measured plates & springs the were fine according to the specs..
Please any ideas???
Please any ideas???
