Hello,
I recently got my hands on a 96 TRX in good shape except non-running with no compression. I pulled the head and it had a bent valve. It had touched the piston, but there was no evident damage to the piston and the cylinder wall looked good too. So I bought a used head off ebay and bolted it on.
The first thing I did was check compression. It came in at a little over 180 psig, so I'm happy with that. I went to start it and if fired right up. It runs good, has plenty of power and shifts through all the gears (including reverse) like it should. But there's LOTS OF SMOKE out of the tail pipe. Clearly oil smoke, not fuel.
So, my first suspect is the rings. Even though I've got compression, the oil ring could be stuck. But, I didn't replace valve seals either. I can't imagine this much oil making past the valves, but who knows. Either way, looks like I'll be pulling it back apart. Is there anything else I should be looking at?
Thanks
Thanks
