Did you try adjusting the cable up on it? It probably does it worse when it's cold, right? If the cable is adjusted right, then it's probably the clutch basket. Those clutch baskets are made of aluminum and after a while the clutch discs wear grooves in the slots in the basket and they want to hang and not release properly. You can fix this by taking the clutches out of the basket and taking a flat file and filing down the notches in the sides of the clutch basket. Just file the notches down until the sides are smooth again, it won't hurt the clutch basket. Try adjusting the cable first, but I'll bet it's the clutch basket worn.
Fileing works but its a temporary fix, you can get a new barnett clutch basket for around $200 bucks they have stainless steel tabs bilt into the billet basket where the tabs of the clutch fingers ride should not ever wear out, put one in my 450ER and it works great.
thankyou for your replies! i was wondering, could you explain where is the clutch basket? is that the plate on the left side? Im a farm boy but realizing four wheelers are quite a bit different than everything else lol
thanks!
thanks!
Pull the right crankcase cover off and it's the first thing you see. Closest to you.
