Well let me first start by saying that you guys have already helped me alot on getting my engine running and now I need a little more help. I was given a 1996 Honda fourtrax 300 that was in very rough shape (broken rear end, fenders, and much more) but hey it was free. After finding out that kill switch does what it says I got it fired up and running. But again no rear end. So after searching craigslist I found a parts fourtrax 300 that was supposed to be a 1997 and instead is a 1990. The swingarms are different between the two and the rear brake set up is as well. So I figured the easiest thing to do would be to swap engines as the 90's motor is no good. I am running into issues getting the 96 motor to match up to the mounting holes on the frame and the driveshaft. Am I beating a dead horse here or will this work.
Thanks
Thanks
