95 300. Been parked for years. Pulled and cleaned gas tank and carb. New shindy kit in the carb. Carb adjusted to factory settings per service manual. I have a high idle. When I rev it it becomes a hanging idle. (Takes a while to return to the obscenely high idle) I’ve had the carb apart a few times now just double checking my work and can’t seem to fine anything. The obvious works as intended. Throttle snaps back as designed, choke raises rpm when on, mixture screw raises idle when I fatten it (back it out)and lowers idle as it’s leaned out (crank the screw in)
What am I missing? This isn’t rocket science :grin
Now just for fun I moved the e clip up on the needle to the last (highest) position and the idle comes closer to where it should be but chokes and wants to stall if given throttle. What am I missing? It’s gotta be stupid simple. Any suggestions?
Thanks
Thanks
