Hello, I have a Canadian 93 trx350 D. I have back tested all the pump and relay connections. All test 12v except relay to pump test 5v when cranking. The bike runs good but stalls when ideling. The pump bench test good works well directly to 12 v but doesn’t always supply fuel to the carb and bike dies. Is this the relay causing problems? (Back story) bought the bike used and it ran well until the pump started acting up, I have removed the fuel tank and cleaned 26 years worth of rust out of it, I am now cleaning the carb. I have not put it back together yet so can’t test the pump with the bike running, cranking produces 5volt at pump/relay connector
