I have a 93 300ex that wont turn over or even click when you press the start button. It has a brand new battery and is bored .5 over and is in a 96 frame/wiring harness if that matters. I'm not sure what's going on if it's something with the wiring/electrical. It is in neutral when I try to start not sure what's up please help.
Have you confirmed you have power to the starter when the button is depressed?
Most importantly, have you confirmed the battery is good? What voltage does the battery show when testing with an ammeter/voltmeter?
Yes I have power to starter and the battery has 12volts
12 volts would confirm your battery is no good..
A good 12 volt battery shows a minimum of 12.4 volts. Can you confirm a more accurate reading or is 12 volts the top reading?
Is it possible just to junk the whole electric and setup so it starts and drives like stuff in the 1960s did?
Nope! Start your own thread and tell us the exact issues in detail.
