Ok. I picked up a 300ex doesn’t fsoark I did all the normal checks and followed the manuals checks the only thing that seems out of place is the manual says that the reverse switch should have continuity to ground when in reverse but it doesn’t it has continuity in neutral and yes it’s in reverse I have checked it several times. I think these bikes don’t start when in reverse. I don’t have much experience with this double cdi set up I am good with the older stuff and have worked on bikes for a long time but this thing is driving me crazy. If anyone has a 93-99 300ex that can check the reverse wire coming from the right side of the case and tell me if it has continuity in reverse that would be great or maybe someone can tell me what I maybe doing wrong or someway to bypass it. According to the manual I think someone put something back together wrong or something needs adjusted but I have read a lot of stuff on the bike and can’t find anything. Maybe it’s the way it should be and the reverse inhibitor is bad. Sorry for the long post
