Hi, I have a trx250x that has been sitting around 5 years. It blew a stator when I was in the desert years ago. Recently I have replaced the stator, cdi, ignition coil, and did an oil change. Also with the help of old forums I have jumped the reverse switch and pulled the cable above the brake pedal tight. This gave me good spark. When I spray starter fluid in the carb it starts right up. I have tried to put the gas tank on and then spray starter fluid. This works barely and I have got on the machine to run for a minute or two. The machine won’t start with just gas. Also the idle screw on the carb is missing so I have to hold the throttle with my thumb( this used to work fine 5 years ago time after time) is this a carb issue? Or maybe valves idk
