Hi -
I removed the right crankcase cover to replace my primary drive clutch. I tried using an impact wrench to get the nut off, but the metal was extremely brittle and it just stripped out. I had to drill a hole in nut and use a chisel and hammer to get it off. The outer tabs of the friction plates were really burnt. I'm guessing the heat caused the nut to become brittle?
In looking at reassembly (after I get new clutch nuts and oil seals), anyone have any suggestions on how to keep the clutch cam plate, spring, and clutch lifter plate in place when I put the cover back on?
