1 - 2 of 2 Posts
I got a 1991 Honda trx250x I ran it for a while then the chain broke the stator case. So I bought a new case and put it back together no spark but the light turned on when kicked over. So I bought a new ignition coil to see if that was the problem I replaced it still no spark so I bought a new cdi box. I thought for sure that would fix it but still no spark. Now I don't know what the problem could be. Need help any suggestions?
Can you get it back to the last configuration when it did have spark? I would go back to your stator cover repair and check connections since you had spark before that. I wouldn't imagine that ignition parts went bad during the time you replaced the cover. It sounds like you have replaced some parts that you didn't have to.
Rob
1 - 2 of 2 Posts
