I found an oil leak from my recently purchased Fourtrax. Its leaking at the drain plug. I thought it may have a worn washer on it so I went to the dealer and purchased a new washer. The washer was too small to fit on the drain plug. I verified that the washer was the correct size and part. It looks like the previous owner tapped out the hole to a larger size. I tried putting the bolt back in, but its stripped out.
What are my options as the larger drain plug is now leaking? Re-tap to an even larger size?
Thanks for the help.
