First post here, looking for some help with this damned 300... I will cut right to the chase.
It will start up and run but not well, and as soon as you try to rev it up, it boggs/dies. Almost like it is losing fire as it revs up.
I have:
Cleaned carbureator about 20 times. Checked for missing pieces/correct jet sizes/etc. Everything seems perfect. Ruling this out. Has fresh gas as well.
Replaced CDI box/Stator. Bench tested coil on machine. Everything seems fine here too.
Replaced piston/rings/gaskets. Motor now has great compression (was low before) No problem here now.
Any ideas? My last thought is possibly the flywheel losing magnetism, I have been in this business for many many years and have only seen this maybe 2-3 times, once was on a motorcycle. When I check for spark, it has plenty when the motor turns over slowly, but as soon as I put a boost on the battery and use electric start, it seems to lose fire...
I am really stumped and have thrown myself at the mercy of the internet. Any help you can give me will be greatly appreciated, I will have a cold beer ready for each of you!
Thanks!
I have:
Thanks!
