1 - 2 of 2 Posts
Hey everyone and thanks in advance to anyone helping!
I have a 91 300 fourtrax 4x4. went to load it on the trailer the other day and wouldn't start. checked for spark and had none. so i put new plug and same thing. I have a second used CDI and tried that and nothing changes. when ever i try kicking it over or electric start i get one spark right away then no more. unless i turn the key off and back on i wont get anything. i have tested all connections to the cdi and the only thing that seems to be wrong is im getting continuity to ground when in neutral when i shouldn't be. i have also tested the stator and am only getting around 2vac on each coil not sure how much i should be.
one spark normally tells me its a bad c.d.i.
1 - 2 of 2 Posts
