91 250x, wont go in gear anymore(worked fine prior)...im thinking clutch kit will fix problem !! is it easy to do ?? any opinions on what it could be or ??
thanks 4 all replies !!
I agree. Can you shift gears, by rocking it back and forth, when the engine is off? If not, you have a transmission problem.Soundslike you may have a tranny issue rather than a clutch
If it's actually going in gear with the engine off, then it would seem like it would have to be a clutch problem. But what I don't understand is that you should have noticed the clutch slipping before it completely quit pulling.tryd what u said n it does go in gear, sorta hard 2 push, back wheels turn tho ! with engine on n in gear it wont pull away to drive ! so clutch or tranny problem
thanks 4 all replies again
