Thanks I hope so ? Pulled into the shop and did a few checks, still nothing bummer.
Must follow diagnostics in service manual and parts links in my signature block.
Is your battery old? D models have to have a good battery To start
spark plug clean? correct plug?
you have to have a neutral light, youR CDI connectors have to be clean (use contact cleaner and plumbers flux brush then apply a thin film of permatex dielectric grease with a clean plumbers flux brush. lastly take the spark plug cap off your coil wire—look at the coil wire and cap connections (corroded?)—snip off a half inch or inch of the wire, brush The cap connector and try again.
