Had my 350 out in the woods the other day and it worked just great. Parked it in the garage and two days later, went to start it and it would not start. Trouble shooting found low compression, and when it was turned by hand, there was definitely a valve/piston contact--but it was slight enough to go thru. Thought I might as well since the electric starter was doing it many times. Pulled the rocker cover and found that the timing was off about 45 degrees or about 5 teeth(I forgot to count). I had removed the tensioner to reset the timing and put it back in so I could turn over the engine by hand with the valves all closed. I was trying to determine if any were bent. the plug was out and I let it suck in air and then put my finger over the hole to see what kind of compression I had. To my surprise, it held compression for several seconds and I could hear no air hissing out thru any valves. As well, when the piston was going down, it would build vacume and hold it for 2-3 seconds and when I removed my finger, it would let the piston drop further.
I will still probably remove the head to check, but what do you guys think about this as a test for good valves. I could see no noticeable difference in gap before I removed the rockers.
Can the timing be off that amount, have contact and still have no bent valves? Can I be that lucky after gambling that the old chain was still OK---it was not, and it is being replaced this time.
Appreciate your thoughts.
