Hello all! I recently became the proud owner of an '88 TRX350D and '88 TRX300 2wd (my first quads, but not my first rodeo in Honda motorcycle rebuilds over the years). They were a 2-fer deal from an old rancher here in Idaho. Both bikes had been sitting outside for about 8-10 years, but the 350D was more complete, so I started there.
I got her running great (won't go into everything I did on the bike, but will focus on engine-related work) after a carb kit, new fuel filter, new fuel pump, new fuel lines, new plug, air filter, oil & filter change change. I scrubbed a mountain of gunk of the cylinder head, to find that one of the valve adjustment covers was leaking (installed new o-rings) and one of the cylinder head cover bolt holes had stripped threads (Helicoil worked perfectly).
It was running pretty well, but wouldn't hold idle unless the idle screw is cranked way in. I pulled the carb and rechecked my rebuild work - broke it all down, sprayed compressed air through all the ports and passages. Set idle screw to factory, minus 1/4 for elevation (I'm at 4000ft), so it is 1.25 turns out from seated. Still no improvement, but ran well otherwise, lots of power.
One note: when reassembling the first time, I noticed the o-ring/seal on the body of the starter valve was cracked, so I replaced with an o-ring I had. Not sure if this is causing it to stick, and precipitating the other issues - but I wanted to note it here.
I did a SeaFoam Top-End treatment, let it hot-soak, then ran it more. Shortly after that I started getting smoke (didn't look like sea-foam smoke, nor did it look like burning oil) and A LOT of carbon blowing out of the exhaust at mid- and high- throttle. Then yesterday, after giving the kids a ride around the block twice, it crapped out completely - died and wouldn't start, unless I was manipulating the throttle. And it will run as long as I keep thumb on throttle, but it runs REALLY rough until it hits a few thousand RPM.
This morning I tore it down, checked valve lash (minor adjustment on one intake valve, but not enough to cause this level of hell).
Its got a beautiful fat spark when I tested the plug, so thats out.
Unfortunately I didn't check compression before, because it seemed really strong (very healthy sounding thump, and very solid in the kickstarter. But I did check it with my gauge this morning, and compression is consistently ~90psi, using the electric starter. I added about a tablespoon of oil in the spark plug hole and readings shot up to ~120psi, which would usually indicate worn rings/cylinder wall.
So I'm wondering: maybe the SeaFoam knocked some crap loose, it wedged in between a valve and seat, and caused a burned valve. Or, the choke was stuck on, causing idle issue and engine damage to the rings/piston/cylinder wall (hence the higher readings when I added oil).
So I'm wondering where I turn next? I'm afraid the next step is to pull the head (was really hoping I wouldn't have to tear down the top-end) and see whats going on in there. Unless you guys have another suggestion or hypothesis? Thanks!!
