I have fire from the stator all the way to the cdi and every now and then i'll have a spark from the coil. However, 9 out of 10 times, nothing from the coil. Coil has checked out to be a good coil. Should i have fire coming back from the cdi to the coil? I assume i would, but not sure. Is there a way to check the cdi? Can it intermittently(sp) work? Or is it either good or bad? Thanks for any help.
Is your bike in reverse? the reason I ask is if you switch to reverse it causes an intermitten spark so you can't start up and go zooming in rewind. In the harness under the frame close to where the seat mates with the tank there are two wires gray and gray/black. disconnect them and put a jumper wire between the two cpming from the front of the bike. try to start if it does you got a bad reverse switch if not pm me I got an electrical breakdown how-to with schematic it's for my quad but they are probably the same. Good luck
got it emailed you the electrical pages from my book
