ok, so I have an 88 Honda fourtrax 300. it was running fine and then it bogged dwn and shut off. I couldn't get it running again. I figured it was the carb, so I got it back to the house and went to rebuild the carb. got the carbapart and realized that the diaphragm for the slide was a little torn. it was way to expinsive to be worth replacing so I just bought a whole new carb. I installed the new carb, when I go to crank it, it will run for random times (usually around 5 to 10 seconds) then shuts off like I hit the kill switch, but I didn't hit the kill switch. I'm not sure what is going on... any ideas. I changed the fuel filter I cleaned the petcock and about to replace it all together. I'm not evan sure if that will fix it... this whole situation is confusing me and my brother both... anything will help thanks!
~Roman
~Roman
