Top end as a result of swimming? Or does it need a top end from age and normal wear? If the former, you will likely need to drive into the engine and get it all clean before replacing the top end and considering it done, because there will be gremlins (sand/silt) all in the block to wreak havoc downstream.Needs topend...
Needs topend...
Looks really good , but , needs an upper , parked in the water , a picnic with ants .@fishfiles gen1 spares for the blue build maybe??
