i have a 88 300 four trax and only the left rear tire is pulling well it seems that way ever time i get himed up that tire is off the ground and it is spining like crazy but i go no where. did i break something?
The only difference in the axle for any year, is that the earlier year axles had, either shorter hubs or longer hubs and I can't remember if the earlier ones had the short hubs or the long hubs. If you have to buy the axle and both hubs, it wouldn't matter which year, but if you just buy the one hub you will have to know which years will fit. Maybe Shadetree can remember which years used the short hubs and which years use the long hubs.not sure about the years that work, besides the 88...... helmut could probably answer this. he or shadetree.
Make sure the oil level is correct and you can try adjusting the clutch free play.ten four. do yall know why it is hard to shift sometimes. low oil maybe?
Find the adjusting screw on the right side of the engine. The adjusting screw takes a flat screwdriver and it has a locknut on it, I believe 14mm.how hard is it to adjust the clutch free play
the early years on trx300's used the long hubs..they changed the wheel hubs lenght's in the first of the '90's..like '90-'94 or so..if your not sure which one you need..you may be better off just getting the whole axle and both hubs..inspect your axle..see how bad the splines are on it ?..it's probally about worn anyway.what years will work with the 88
bad idea to weld the right hub..you won't be able to remove the brake drum..not without grinding the weld off.if you are really strapped for cash you could always weld your hub to the axle.
You can still change the brakes, though. You can slide the drum back enough to change the brakes, but you can't remove the drum all the way off the axle.bad idea to weld the right hub..you won't be able to remove the brake drum..not without grinding the weld off.if you are really strapped for cash you could always weld your hub to the axle.
Yeah, if you weld the left hub, you can't get the axle out of the rear diff.oh yea i totally agree. I dont believe in rigging things. But the same could be said about the left side hub i think. Doesnt the rear axle have to removed from left to right?
