Hello All,
A video speaks a thousand words: here is a video of what my 350D is doing (link)
As noted in another thread, I did a major rebuild on this machine and as part of the rebuild, did a valve adjustment. Now before the rebuild, I had zero valve noise but the timing was off on this machine. A new timing chain later and countless other pieces, I hope to have fixed that, but now I just have so much valve noise I can't tell anything at the moment.
Valves were adjusted at TDC to fit a 0.003" (0.076mm) feeler gauge at ~16Nm torque, with the gauge barely able to fit the gap when I was done and dragging through. I've tried it with a little bit bigger of a gap than that (where it slid and almost no resistance was felt at all), but neither way makes a difference.
What is with all this clanging guys? I'm concerned because this noise never happened before on this machine!
Please advise, thanks!
