1 - 2 of 2 Posts
did the 87 trx250x have a chain tensioner? I have an aftermarket swingarm on mine and for some reason i cant tighten the chain like normal.
Not exactly sure what you mean by "chain tensioner", but it had the adjustable bearing carrier in the rear that you turn to tighten the chain. It also had a roller at the bottom front of the swingarm to keep tension on the chain when the rear suspension is at "full droop". I'm assuming the latter is what you're speaking of.
1 - 2 of 2 Posts
