Hey everyone! So I'm not too far in but I've got some questions... firstly, are the piston rings supposed to be fairly loose on the piston? I've never dealt with them before.
And I cannot seem to decide whether or not there is play where the connecting rod meets the crank because the gears all move and make noise when I push and pull on the piston. Honestly it feels pretty good to me. I can't discern any movement that shouldn't be there.
And how do I check if the wrist pin is bad?
And then lastly, since both of my 350's are making similar noises from the crank (or so it seems) is there any part that often wears out on these that would a cause a noise like that? Can a wrist pin not make any noise at the piston but have that sound travel down the connecting rod to the crank? I've tried many times with my stethoscope and the noise is always loudest when I've got it near the crank. I'm taking it out anyway because I want new crank bearings in it. I'm just trying to get ahead if it turns out not to be the crank or rod bearing. Thanks a bunch!
