While I was waiting for the Hondabond on the rocker cover to cure I decided to drain the fuel tank, clean it out and put in a new fuel filter. Did so and its cranks fine and I hear the fuel pump running but its not getting to the carb. When I squirt a little gas into the venturi it fires right up. I didn't take the petcock apart as I couldn't find parts/gasket anywhere. But the bike was running when took it apart, so I don't think the screen in the petcock is plugged, and gas came out when I changed the filter. I'm thinking there is a procedure or "trick" to priming the pump. The manual is silent on the issue.
