1 - 9 of 9 Posts
Hey guys, picked this old girl up cheap, and it's in good shape the way it is. Previous owner put some LED lights on the front which will be coming off, added a hitch mount off the rear bumper which will be coming off, and added a winch on the rack which will be staying if I can get it working/replaced. I'm pretty sure it needs a timing chain, but other than the noise, it runs great. I'll keep this thread updated as I go, I'd like to get it stock-looking with a lift and stuffed tires. Your thoughts and advice is welcome!
Looks very tidy indeed, good buy :)
My first thoughts are, definitely take the winch OFF the carrier (rack) it WILL bend the carrier and other frame components.
I'm not sure that lift kits are available for these, you shouldn't have to many issues going from a 24" to maybe a 26" tyre though, just check clearances before buying.
Very nice!
Sent from my SM-G550T1 using Tapatalk
Very good purchase and a classic. I don't think a lift kit or winch mount available. I am planning to put a winch on mine--the old Cycle Country plow mounts you have are very good and intended to be used with a manual plow lift.
Check out this rare NOS headlight riser
I was thinking about that, the previous owner used the winch for the plow, which I also have. Where would you mount the winch?
I don't know of any other place to put it than the rack...
I bought an old Cycle Country winch mount it was made for the bumper you have and the mount plate too short so I have to fab one and mount it with u bolts
Does anyone know if the headlight riser bracket is a Hondaline part or aftermarket? I looked on the parts diagrams for all years of the trx350 and don't see it as an option but have seen many of these bikes with them installed.
1 - 9 of 9 Posts
