Does anyone know if there is a cross for the tie rods on a 87 fourtrax 250 utility? All I can find for the tie rods is for the sport model. Any help is greatly appreciated
prob because most parts for that model are discontinued today. its used all the way for parts for yours. ebay or a salvage yard is your only hope, or power sports nation for used tie rods.
I've had TRX250 Fourtraxs , still have a bunch of parts , seems I remember that you can use the ones off a Honda 300 , 350 Rancher or even a Yamaha 350 or 400 , they won't like exactly the same but will thread up and work , they are at least 4 maybe 5 that look different , take you old one and the steering rod to a Honda dealer and ask for a 300
300 fourtrax, 350 rancher, 400 foreman and 450 foreman will work fine. Same rod thread and same taper :)
what about the length ??.
I'm pretty sure there the same, I have several I can lay out against a rule tomorrow and upload a pic :)
I posted a pic a while back on one of my threads with 5 different versions of tie rod ends , Honda shows 4 different part numbers for the tie rod ends , some are a bit shorter on the threaded side , just adjust it to where it needs to go , I have never snap one off at the threaded side yet
