hi
Hello all. I am also new to the forum and atv's! I am having similar troubles as mobo. I have an '87 fourtrax. Im guessing its the utility. A friend gave it to me 2 weeks ago. He said it was running just a few weeks before he gave it to me. As far as i know, the green neutral light on the controls doesnt work. It hasnt yet. Also, the neutral indicator behind left footpeg is missing also. So, im not sure when its in neutral. I pulled the plug and grounded it to the cylinder, and I do get spark. I put my finger over the spark plug hole, and i can feel the pull, and exhaust while pushing the starter button. I can also see what i believe to be the piston moving up and down through the hole! So would the compression be ok? I cleaned the air filter and box. I tried removing the carb, but i couldnt figure out how to remove the throttle cable! I sprayed some carb cleaner in the carb, and let it sit for a while. Still nothing! It cranks over, but it will not start. Is there a safety switch that would cause it not to start? Im new to all of this, and any help would be greatly appreciated!!!! Thanks
