Hi bought a cheepy borescope for $20 about 2 years ago—I scratched the lens pretty bad, but it works better than nuttin
The attached pix are from an ‘86 TRX350 tank—showing the interior plumbing and the screens built onto them. First is the reserve pipe with the drain bolt removed; 2nd is the reserve intake screen 3rd is the plumbing that attaches to the petcock 4th is the bottom of the tank where water collected 5th shows the rust line.
Tank is not terribly rusty—you can see the some of the rust is flaking off in pretty thin pieces. I will use a vinegar soak and a pound of steel BBs to gently knock the rust off. Pics demonstrate the value of draining the tank annually and keeping it full to prevent condensation. Also important to use a flexible long handled small diameter bore brush to gently remove scale from the plumbing
The reason I use BBs is that they won’t damage the intake screens like bolts and other stuff people want to use. Even the polymer coatings that might work in straight draining tank might clog up these screens.
I checked the tank I cleaned two years ago—couldn’t take pics cuz the tank was full. I’ll drain it down maybe this weekend and show how well the soak worked.
