hi, i have a honda trx200sx fourtrax with a honda atc 200s motor in it. it has the stock 11 tooth drive sprocket in it. i was wondering if there is anything i can do to it to make it faster? it also has a honda 350x carb on it. is this ok? i believe it should have more power than it does. thanx for your help
larger front sprocket say 14 tooth and a 36 tooth on the rear = more topend also a shorter tire will help 20x10-9 is a good trail size tire. check that chart though
Welcome to the forums
The only problem with going to a bigger front is you will loose bottomend power a 200 motor does not have much power sorry i know that not what you want to here but messin with the gearing you will give up somethin to get somethin.
