i purchased a 86 trx 70 for my son. NON running. Engine is in time per flywheel and camshaft marks. i have checked valve clearances to make sure they were not overtight. They are in tolerance. Engine will not crank. Will not hit once on starting fluid either. How much compression should i get, as im checking this next. On/Off switch and neutral safety switch are both ok as well.
