Hmmm. Over 60 views and no response after 18 days. Did I offend someone? Don't see how I could have... I did introduce me and my old gal.
Anyway I googled my issue and of course found plenty of threads from this site over the years. So I know the tensioner "lifter" assy on this model is auto adjusting as the chain stretches to maintain correct chain tension. If it's at the full extent of it's travel then the chain and possibly other parts should be replaced with quality parts, not the China crap, and should be replaced before it becomes so loose that it jumps a tooth and causes major damage. As for those aftermarket adjustable ones they don't seem to be a good idea as it's not a proper fix, and just asking for worse trouble. Btw, anyone know why is it called a "lifter assy"? All it does is put lateral pressure against the actual chain tensioner guide.
Now I haven't removed the adjuster yet. It likely has never been removed and I'm wondering if I should have a new gasket at hand or are they good and sturdy? Also, I did see at least one post from a mod here saying how to test chain stretch by inserting the the adjuster assy with shaft extended until contact is made with the tensioner and then measure the gap, gasket included I believe. I don't recall the exact parameters but 1/8" comes to mind for some reason, maybe that was a minimum? I'm not sure now.
So back to this auto tensioner. They seem to be dependable from what I've read, but I haven't found anything about how they do fail. I'm not familiar with the internal workings, movement and pressure of the assy. How much does this unit actually move over the life of the chain, or is it more of a static pressure against the chain tensioner guide? I guess the guides must wear some too but to what extent I have no idea. So I guess my question would be do they get sticky ever? Maybe with a cold engine, and then free up when warm? That would be an easy fix lol.
So to me this still boils down to the fact that the engine noise is predominantly only at cold start at idle. With a bit of choke on you can still just hear it. After a minute of sitting and then a leisurely two minute drive total up the road and back and when I park it the slapping noise is gone so long as a good idle speed is maintained. If it does falter I can just hear it a bit.
So this noise is not present at all when the bike is moving or when the revs are up a bit. I guess my big question would be with these symptoms what would your opinions be on the possible extent of the chain stretch and also what is happening that causes the noise to go away once the engine is warm?
Tks for any replies. I appreciate it.
Cheers
