Hi everyone I have a 86 trx350 and I can not get the rear brake pedal off any help would be awesome
The pedal it self I push the brakes and the pedal stays down and it’s seased on and I can get it off the grease itDo you mean the pedal itself or the brakes are stuck on?
Min doesn’t need to be replaced it needs lubed up so it moves back up when you hit the brakesSpray it with Deep Creep and let it work in overnight. There should be a cotter pin and washer on the mounting shaft—they hold the pedal on the shaft.
Mine was also a rusty piece and I bought a NOS to replace it—you can find them pretty cheap.
