1 - 2 of 2 Posts
86 honda, fourtrax. keihin carb, CLEANED TO LIKE NEW, installed a NEW HONDA FLOAT VALVE, gas will not cut off...
float is a non adjustable solid plastic with no leaks. float level rises too high and pours out the overflow hose..
brass float seat in carb body needs to raise up? looks to be PRESSED into carb body? or a longer float valve?
is there a replacement float that has the adjustable metal tab to set the correct float height?
Cannot get a new float seat.
Are you sure you have float valve 16155-397-971? Maybe they sent you the wrong valve.
Have you modified the seat?
Download the service manual from the link in my signature block below.
Use OEM parts finder at Rocky Mountain atv to find another valve or try rebuilding with a Shindy or K&L carb kit.
1 - 2 of 2 Posts
