Just picked up this machine a while ago. I seem to be having a ton of trouble with the shifter. It doesn't always want to get into gear, or neutral, or reverse. Sometimes it will go right off the bat, other times it will take messing with the shifter for a minute or two to get it into the sweet spot. The shifter is a little sloppy with a bit of up and down play in it.
The outer works are tight, seems like something inside causing the trouble.
Any educated guesses what I'm in for? Bad drum or maybe a little easier with a bad pawl?
