Just got in from a weekend ice fishing trip. - 15 C
Quad just not running right. Will be looking at fuel filter first ,whats next?
Quad runs really good at first for the first 15 mins then it starts running like the choke is on or on one cylinder if it was a two cylinder. louder and no power.
When it starts happing i am normally in 3 gear then after 200 feet i shift to 2nd then about 200 ft again I have to shift to 1st . it starts again and does not goo away.
Almost sounds like floating valves when over speeding the engine.
If I shut the engine off then hit the starter ,if feels like the timing is out and has a hard time to crank for a 1/4 of a revaluation ,then it cranks normal and starts.
When I let the quad cool down ,it runs fine again .
I did shut off the fuel and let it run till it stopped so i could hear the electric fuel and it sounded normal.
Fuel fitter ? Electrical ? Failing spark plug ?
Any one else have this before.
