First I would like to say I have been reading this forum for a long while and it's great.
Pulled my bike out the other day after it had been sitting for a few months . She started right up so I pulled it out of the building shut her down topped of the gas and oil and headed out. After about a mile she started sputtering and coughin ,so I turned around and headed home. I was thinking maybe a little water in the gas so I replaced the filter emptied out and flushed the tank perged the lines and tore the carb down. Evert hing was cleaned and left to dry.
After putting it back together she works exactly the same ,when running with the breather tube off some fuel vapour can been seen coming from the carb and she blows black smoke. Also the plug is coated black and if she won't idle unless I pull the choke plunger then it will suck air through that hole and run much bether .
I am starting to wounder if I am even on the right track ,I have had the carb apart so many times I have lost count. Any input would be appreciated I need this thing to get my wood.
